Hey y’all, Carolina from Support here again!
Did you know you can build and test your solution without real physical devices?
You can! Using our device emulator!
It’s built directly into the Device Management console and allows you to simulate data streams instantly.
You can use it to validate your dashboard, widgets, and action triggers ![]()
Hope this tip helps and you can start building right away!
Happy Week,
