Analysis With Data in Bucket
Hello, I would like to know if it is possible to create an analysis script with all the data that is in a bucket of a device, for example, I have current values and I want to calculate energy consumption, inserting voltage and power factor data. power as constants.
Hi João Carlos,
You can definitely do this by using our SDK. You also have access to multiple Analysis script examples when you first create your analysis here:
I’d suggest starting of with the “Operate data from devices” Analysis to better understand the possibilities.
OK thanks! I’m going to do some tests here!
