Hy, guys!
I am trying to use the new data analytics with aggregate data, but the timezone present in the widget maybe will confuse the final user. The aggregation algorithm create the group in 00:00 UTC, when put in the widget, the user time zone convert the date and, if the timezone is negative, change the date to previous day.
The print above aggregate the data from 09/26, but in the widget, show 09/25.
Is there a way to fix this?
