Variable out of scope
@julien terrier
I’m using analysis script to a specific needs and I want to use the same variable in and out of scope, unfortunately this variable isn’t modified by the function and I didn’t understand why?
The script:
const Analysis = require('tago/analysis');
const Utils    = require('tago/utils');
const Device   = require('tago/device');
var x_value = 4;
// The function myAnalysis will run when you execute your analysis
function myAnalysis(context) {
  // reads the values from the environment and saves it in the variable env_vars
  const env_vars = Utils.env_to_obj(context.environment);
  if (!env_vars.device_token) return context.log('Missing device_token environment variable');
  const device = new Device(env_vars.device_token);
  // create the filter options to get the data from Tago
  const filter_x = {
    variable: 'accelerometer_x',
    query: 'last_item',
  const filter_y = {
    variable: 'accelerometer_y',
    query: 'last_item',
  const filter_z = {
    variable: 'accelerometer_z',
    query: 'last_item',
  device.find(filter_x).then((result_array) => {
    // Check if the array is not empty
    if (!result_array[0]) return context.log('Empty Array');
    // query:last_item always returns only one value
    const variable = result_array[0].variable;
    x_value = result_array[0].value;
    const time = result_array[0].time;
    // print to the console at Tago
    context.log(`The last record of the ${variable} is ${x_value} and. It was inserted at ${time}`);
    const obj_x_to_save = {
      variable: 'x_value',
      value: x_value,
    device.insert(obj_x_to_save).then(context.log('1 Successfully Inserted')).catch(error => context.log('Error when inserting:', error));
    context.log('x in scope = ', x_value);
  }).catch(context.log); //just prints the error to the console at Tago
  context.log('x out of scope  = ', x_value);
    const obj_to_save = {
      variable: 'battery_level',
      value: x_value * 3,
    device.insert(obj_to_save).then(context.log('2 Successfully Inserted '));
// The analysis token in only necessary to run the analysis outside Tago
module.exports = new Analysis(myAnalysis, 'MY-ANALYSIS-TOKEN-HERE');
The console log:
I expected to see x out of scope = 2 but not at all…
Certainly something is wrong but i don’t no what thank you for your help.
