Is it possible to use more than one variable in a widget formula.
For example I have a variable called “revolutions” which is depicted on a bar graph where the variable comes from my IOT endpoint and then I made a step button widget to change a “calibration” variable. So I want to divide the “revolutions’” by the “calibration” in a formula applied to the bar graph.
Hi @m.harding,
I checked with our team, and it’s not possible to use more than one formula on the widget.
Hi Aline,
Thanks for your reply. But to be precise what I was asking if I can use more than one variable in only one formula on one widget?
Please can you check that for me.
If not, would I have to write a script to do the calculation?
Many thanks
Mark
In the end I used Actions to trigger an analysis, loaded the variables in a script, did the maths and saved in another variable which I then displayed on a graph.
Mark
