Using iFrames in your RUN
iFrames in your RUN
The TagoIO platform has a very powerful feature when creating your RUN: the possibility to show iFrames in your RUN (RUN is your application that is accessed by your users).
What can you do with iFrames in your RUN? You can show components that aren’t native from TagoIO platform, to exemplify this, take a look at the image below that brings up a RUN with a Google form.
As you can see from the image above, you can add a support center in your RUN. That’s the power of iFrames, it makes the development of your application much more versatile and agile. Now, let’s see how you can get the same effect on your RUN.
How to use iFrames in your RUN
To use iFrames in your RUN, you only need two simple steps, which are as follows:
  • Get the iFrame URL you want to use, you can use the example above through the following link: https://forms.gle/t1xNbMZjMMb4N6ti9
  • Go to your RUN > Sidebar > Select the option “Show iFrame" and paste the iFrame URL;
That’s it, simple like that and you have a good use case for iFrames in your RUN. Let me know if you have any questions about this post!
