Run your own payload parser
@Aline Tusi
At some point you may need to create your own parser for reasons like: you are designing your own hardware, it is not listed in our list of devices, or you just want to post-process the data coming from the connector. I will show how you can do that.
  • Go to Devices;
  • Select your device from the list;
  • Go to the ‘Payload Parser’ tab;
  • Mark the button ‘Run you own parser’;
On the example above, I chose to use a snippet parse Exemple, but you can create and edit your own parser as needed.
Tip: Watch the tutorial video below:
Hey, I want to know what you think about this tip, let your comments below!
Cheers!
