Refresh dynamic table after analysis run
@Andrew Sevil
Hi everyone, I’ve created a dashboard to allow a client to modify two device items, namely “name” and a parameter called “offset”. Here is a screenshot of the dashboard.
When I select the filters for the blueprint, then press the “load data” button, the dynamic table populates.
The analysis deletes the previous data when the analysis runs, but the dynamic table simply adds the new device details, and there are then two in the table. Is there a way to get the table to refresh to only show the newly selected device?
If I hit refresh for the page through the browser, it refreshes correctly, but that could be problematic through the RUN app…
Thanks in advance. Andrew.
