My code:
Analysis Example
Minimum, maximum, and average
Get the minimum, maximum, and the average value of the variable temperature from your device,
and save these values in new variables
Instructions
To run this analysis you need to add a device token to the environment variables,
To do that, go to your device, then token and copy your token.
#* Go the the analysis, then environment variables,
type device_token on key, and paste your token on value
from tago import Device
from tago import Analysis
The function myAnalysis will run when you execute your analysis
def myAnalysis(context, scope):
reads the value of device_token from the environment variable
device_token = list(filter(lambda device_token: device_token[âkeyâ] == âdevice_tokenâ, context.environment))
device_token = device_token[0][âvalueâ]
if not device_token:
return context.log("Missing device_token Environment Variable.")
my_device = Device(device_token)
This is a filter to get the minimum value of the variable temperature in the last day
minFilter = {
'variable': 'variavel',
'qty': 1
Now we use the filter for the device to get the data
check if the variable min has any value
if so, we crete a new object to send to Tago
min_result = my_device.find(minFilter)
if len(min_result[âresultâ]) and min_result[âstatusâ] is True:
# context.log(min_result["result"])
min_result = min_result["result"][0]
minValue = {
'variable': 'temperature_minimum',
'value': min_result["value"],
'unit': 'F',
# now we insert the new object with the minimum value
result = my_device.insert(minValue)
if result['status'] is not True:
return
# context.log(result['result'])
else:
context.log('Temperature Minimum Updated')
else:
context.log('Minimum value not found')
This is a filter to get the maximum value of the variable temperature in the last day
maxFilter = {
'variable': 'value',
'query': 'max',
'start_date': '1 day',
max_result = my_device.find(maxFilter)
if len(max_result[âresultâ]) and max_result[âstatusâ] is True:
max_result = max_result["result"][0]
minValue = {
'variable': 'temperature_maximum',
'value': max_result["value"],
'unit': 'F',
# now we insert the new object with the Maximum value
else:
context.log('Temperature Maximum Updated')
else:
context.log('Maximum value not found')
This is a filter to get the last 1000 values of the variable temperature in the last day
avgFilter = {
'qty': 1000,
avg = my_device.find(avgFilter)
if len(avg[âresultâ]) and avg[âstatusâ] is True:
temperatureSum = 0
for item in avg["result"]:
temperatureSum = float(temperatureSum) + float(item["value"])
temperatureSum = temperatureSum / len(avg)
context.log(temperatureSum)
avgValue = {
'variable': 'temperature_average',
'value': temperatureSum,
'unit': 'F',
result = my_device.insert(avgValue)
else:
context.log('Temperature Average Updated')
else:
context.log('No result found for the avg calculation')
The analysis token in only necessary to run the analysis outside TagoIO
Analysis(âMY-ANALYSIS-TOKEN-HEREâ).init(myAnalysis)
