No True/False formula on Table Widget?
@Nicolas Kyriakou
I am trying to add this formula to the some variable on a table: $VALUE$ == 1 ? “True”: “False”
But it doesn’t seem to work, I have tested this on card widget and the formula works fine. Does the table widget need a different formula for True/False or is it not possible to do?
If it’s not then I can just add the alarms as True/False from the decoder.
I have this table with screenshots for more info:
Card:
