Connection refused, invalid payload. Using C-Curl
Hello, I am trying to upload data (json) to TagoIO from a C code using Curl but I got some issue. If I try to upload it through Python the same json file it works properly. function to upload data to tagoio void sendJsonFile(const std::string& filePath,
Multiple device on normal dashboard for a push button widget
Is there a way for me to use an analysis script or anything else for my normal dashboard that uses a push button widget to get data from multiple devices with the same tag keys and values?
Expression in Start and End date
Hello. I would like to know if there is any way to use regular expressions to work with dates in the tago platform. Being more specific in the start_date and end_date. Here is the line of code that I would like to leave with the expression: const dados_fevereiro
Use lora gps time on map
Hello tago team, I am developing an online and offline equipment tracking application. Everything works well when it is online because it uses the time assigned by tagoio. but in cases where it is offline and when it reconnects to send the saved data,
how to trigger an analysis from within inside running analysis
Hello, I'm trying to trigger an analysis from inside another analysis. I've found https://js.sdk.tago.io/classes/_internal_.Analyses.html and trying to use it. But I'm having issues initiating new Analyses class.. what is the format, what parameters does
Connect Tagocore with tago.io - not possible
Hello, I have a tagocore installation running and have integrated the first sensors from the TTN. This also works, I would now like to establish the connection to tago.io at the same time. TagoCore is installed in the current version on a LINUX server.
CANNOT SEND COMMAND TO ESP32
const { Analysis, Device } = require('@tago-io/sdk'); const axios = require('axios'); // Import axios library async function startAnalysis(context, scope) { console.log('Analysis started, preparing command...'); // Command to send to the device const
Group in Graphic bar
Hi! Could you tell me why it is not possible to display the group name in the vertical bar graph? It only shows the value of my variable instead of showing the group name, just like when I'm in edit mode. My variable already has the group name defined,
Automatically download and delete a device chunk with analysis
Has anyone set up some up some sort of automation to create a chunk file and delete the chunk per device? It looks like I can set up an action on the 1st of every month to run an analysis. Ultimately I want to send that file to an external bucket. Open
Copying files from Tago Files to AWS S3 Storage
Hello, One of our clients requires us to make backup copies of Tago files in their AWS S3 storage. I know Tago is AWS based. All of the nodejs examples I can find require the AWS-SDK library which I don't think is available in regular analysis code. Two
Request for help with creating automation
Hello, I would like to ask you for help in creating an automation. I have this door contact https://www.dragino.com/products/lorawan-nb-iot-door-sensor-water-leak/item/157-lds01.html Even if the door is not opened, the device will send a message once
Dynamic table and GPS co-ordinates
I have created a dynamic table which contains a column containing Location GPS coordinates for the sensing record (see attached image) What I would like to provide to user is the ability to click on the location gps co-ordinate and show the location on
Authorization denied - Sending Downlink using dashboard through Analysis
Hi TagoIO Team I have tried to use the updated snippet code example provided for "Sending Downlink using dashboard": /* ** Analysis Example ** Sending downlink using dashboard ** ** Using an Input Widget in the dashboard, you will be able to trigger a
To find if email exist.
Hello , Can i check by analisys if email/user already exist ? Can`t find it in documentation
Sum of data for a selected time period?
@Andrew Sevil Hi, is it possible to have a widget display the total of a variable over a time period specified by the widget? So if I set the widget to show the last 7 days of a variable (lets say rainfall), the result is the total of the period dis
Raw Payload
Hello everyone! I need your help. I'm connecting a device via MQTT but I'm having a problem entering the data. I've already connected another device to the tago and it was pretty smooth, but this one is giving me these problems below in the photos: The
Payload error
Hola, Estoy intentando analizar la carga útil pero me envía un error. ¿Podrías decirme qué estoy haciendo mal? Datos: [ { "variable": "chirpstack_payload", "value": "{\"devAddr\":\"007cf8e1\",\"fCnt\":2234,\"fPort\":2,\"deduplicationId\": \"47c02bcb-9954-4d0f-b51b-8d5eb34f008d\",\"time\":\"2024-03-30T17:24:49.610374+00:00\",\"deviceInfo\":{\"tenantId\"
Link device with bluedash using analisys
Hello, We are adding devices using input form and trigger analisys to do it. Is it possible to link device to specific bluedash using analisys ? For example if device has parameter/tag A. It will be linked and connected to bluedashboard - A If device
How to integrate with KPN Things Network
This guide will walk you through the process of integrating a LoRaWan device with the KPN Network and TagoIO. By following the steps outlined below, you will be able to set up your device for both uplink and downlink operations, enabling seamless data
To know the number of emails used by each run user
Good day, I would like to know if there is any code for an analysis to be able to know the amount of emails sent by the run user. Let me explain: each end user can send a csv through a widget, but I would like to limit the amount of emails that can be
Custom "No Directory" Widget
After cloning the repository to test, when I try to follow the steps I get an error like "directory" does not exist.
Dynamic Widget Title
@Vincent Raaijmakers Instead of a fixed text, it would be great to have dynamic the device name (label) as title. This works great using blueprint dashboards as you can add a number of widgets on your dashboard and get the title automatically set. V
Maps widget with a circle around the location
Dear all, I had to draw a circle around the device last location and did some workaround: 1. added a variable to the payload, "range" as a fence format: { "variable": "range", "value": "Range: 36.75", "location": { "type": "Point", "coordinates": [ -46.63629,
Write Analysis to Get API call From the weather app and display the information on a widget
Hello! I am having a hard time writing the code for the analysis in extracting the API information from the weather app. I know I will need to store the data in the bucket, and have the API Key for the weather data, but knowing the parameters of which
Missing "analysis_token" environment variable: External Analysis Togo-SDK
Hi Folks! I am trying to run external analysis from a Tago SDK on Python, but I'm encountering an issue: 'Missing "analysis_token" environment variable' even though I've set the token parameter. Connected to TagoIO, Getting analysis information... Analysis
Multi-line and inline formatting text widget options
Hello, I have some JSON data I want to display in a text widget, ideally across multiple lines. Is it possible to apply a formula like JSON.stringify($METADATA.myjson$) for say a Display Widget? Alternatively is there a widget that supports displaying
Topic and Payload non-platform standard
Hola!
I want to work with the following topic and payload: 023-06-28 22:53:27: [MQTT] Device publish {"topic":"Advantech/74FE486BAA2A/data","payload":"{\"s\":7,\"t\":\"2023-06-29T01:53:27Z\",\"q\":192,\"c\":0,\"di1\":false,\"di2\":false,\"do1\":false,\"do2\":false,\"ai1\":0.000,\"ai_st1\":4,\"ai2\":0.000,\"ai_st2\":4}","qos":1,"isHex":false,"bucket":"6499c4e835b04a000efbad2e","messageId":3400}
Input Control Widget Confirmation
Hello, This would be very easy to add and I believe necessary. The input control widget currently does not have a confirmation dialog box that pops up when you hit the button. I need this so someone can be sure and not submit anything on accident.
Multiple Variables in Custom Widget
Hello everyone! I'm trying to build a custom widget (just for extra information, it's a graph whose data points will derive from a calculation involving data from multiple variables of the same device bucket) and i'm having trouble extracting data from
Range of scale for multiples Axes
Hopefully someone can help. Need to config a graph with 2 axis where I want to set the range of the scale of each axis. I can select it fixed instead of dynamic and it applies for both sides, but I couldn't find a way to set up the range for each axis
Linking to blueprint device dashboard with an internal link
Hi everyone, Last week I worked on creating a blueprint overview dashboard to show the last known locations of every tracker and storing that in a dummy device with a mutable bucket (following this post here). Now I wanted to add a link to the device
HTTP GET request to Tago Core API with advanced parameters
Hi! I send request: curl --location 'http://192.168.0.195:40083/data?variables=myvar&query=last_item' \ --header 'device-token: 953a6fa8-ac1b-456f-XXXX-11b32211a871' And in output I see: {"status":true,"result":[{"id":"710a50f15b0740cbe03565ef","device":"710a20c6b8f8efaa06a51bce","group":"c6b5104b1d28af9252d4a017","time":"2024-03-14T15:03:29.317Z","value":"user01","variable":"myvar"}]}
Widget in Map Infobox
Hello everybody! I'd like to know if there's a way to put some visual information on my infoboxes within my Map widget. Is this possible or would i have to create a custom map widget from scratch in order to implement this feature? Thanks!
Data record
i have a question? If the data record fill up, the TAGO application will no longer give me data or the data will simply be deleted and data transmission will restart.
How to access Device query using listDevice ?
Hi, I am trying to use filter in listDevice to access device query but the function is returning query object of other device. Expected Device ID and returned device ID does not match. I have used filter in Java script works fine but in python script
minimum value Y axis auto-scale not working
Hi we are recently finding that setting 'Dynamic' scaling option for the Y-axis only works for the upper limit and set the minimum to zero. Is there any fix for this?
Connector or Network Payload Parser Logging?
I am working on a custom payload parser that will run on my connector. If I use a console.log, where is this information printed? My code isnt running, but I am having a hard time troubleshooting without logs....
Cylinder Widget - Range from variables
Hello, I am trying to utilize the Cylinder Widget. The user will need to specify the max height of their tank. My original plan was to utilize the Input Control module, but I am not sure if that is correct. What is the proper way to ask the user to input
Payload parser
Hi, I am trying to get a payload parser together to exclude some variables from a bucket. Can anyone see a reason for this not working and where I am going wrong? Many thanks. //ignore certain variable const ignore_vars = [ 'lora_bandwidth', 'txinfo_frequency',
Change Variable if Date is today
Hello, is there a sample how I can change a value of a variable of an Device when the date is the same from antoher variable of the Date? Thanks Fabian
Next Page
