New feature: edit Dynamic Table fields in a modal
@Aline Tusi
A new feature was released for the Dynamic Table widget. Now you will be able to edit each field in a modal individually.
However, to activate this feature you will need to give this control for your user on the widget configuration.
Go to the User Control, then activate the button named “Show modal window” and in sequence activate it to the variable that you want. Click to save.
After saving it, the Dynamic table will be displayed normally, with an icon pencil on each line. Click on this icon to edit the modal, then click to save it.
The modal fields will now be updated, and it will be displayed like the example below:
Enjoy this feature and apply it to your Dynamic table widget. If you have any questions or suggestions, please leave a comment below.
See you!
