Khomp NIT21LI and Tago dashboard (default)
@Andre Antivilo
Hi, I am trying to connect and see data from a Khomp NIT21LI endpoint using LoRaWAN Everynet network. I’m using NLT, and the network is running fine. The problem is that I don’t know how to decrypt the payload!
“variable”: “encrypted_payload”,
“value”: “HN6xhxnsmBgUsa91ftT/0DQ4WDY=”,
“serie”: “1634235535664”
        "variable": "time",
        "value": 1634235535.516,
        "serie": "1634235535664"
        "variable": "packet_id",
        "value": "98861a13387416186cce32e03d493220",
        "variable": "gateway",
        "value": "b0fd0b7003e90000",
        "variable": "gps_time",
        "value": 1318270753384,
        "variable": "delay",
        "value": 0.09307336807250977,
        "variable": "datarate",
        "value": 3,
        "variable": "modulation_bandwidth",
        "value": 125000,
        "variable": "modulation_type",
        "value": "LORA",
        "variable": "modulation_spreading",
        "value": 9,
        "variable": "modulation_coderate",
        "value": "4/5",
        "variable": "hardware_status",
        "value": 1,
        "variable": "hardware_chain",
        "value": 1,
        "variable": "hardware_tmst",
        "value": 389946300,
        "variable": "hardware_snr",
        "value": -5.8,
        "variable": "hardware_rssi",
        "value": -91,
        "variable": "hardware_channel",
        "value": 5,
        "variable": "gps_location",
        "value": -23.93330955505371,
        "location": {
            "lat": -23.93330955505371,
            "lng": -46.33211898803711
        "variable": "gps_alt",
        "value": 56,
        "variable": "time",
        "value": 1634235535.3742936,
        "variable": "freq",
        "value": 916.2,
        "variable": "size",
        "value": 33,
        "variable": "port",
        "value": 4,
        "variable": "duplicate",
        "value": false,
        "variable": "counter_up",
        "value": 60,
        "variable": "header_class_b",
        "value": false,
        "variable": "header_confirmed",
        "value": false,
        "variable": "header_adr",
        "value": false,
        "variable": "header_ack",
        "value": false,
        "variable": "header_adr_ack_req",
        "value": false,
        "variable": "header_version",
        "value": 0,
        "variable": "header_type",
        "value": 2,
        "variable": "rx_time",
        "variable": "encrypted_payload",
        "value": "HN6xhxnsmBgUsa91ftT/0DQ4WDY=",
I’m using the default payload parser for LoRaWAN from Tago with a little modification:
// Search the payload variable in the payload global variable. It's contents is always [ { variable, value...}, {variable, value...} ...]
const payload_raw = payload.find(x => x.variable === 'payload_raw' || x.variable === 'payload' || x.variable === 'data' || x.variable === 'encrypted_payload');
But I can’t see temperature, humidity and battery voltage variables. Any suggestion?
