Icon widget size adjustment
@SA
Is there a way to reduce the size of the icon widget into a little square? See the attached image, the card widget can be made into a small square but the icon widget can not be reduced in width beyond what is shown.
Also, the visualization configuration for icon widgets on a blueprint dashboard is confusing, it appears under the blueprint device section rather than the visual section below. tago icon widget
