Good Morning,
I’m sending some data received from my device to a pivot table, but I didn’t understand how to add the ‘serie’ field to my code. My data are on separate lines, I believe it is for this reason.
Good Morning,
Hello @ghasantos, you can send the series as a json field when you send the data. More information https://docs.tago.io/en/articles/5-other-concepts
for example:
"variable": "myVariable",
"value": 10,
"serie": "mySerie"
if that doesn’t help, put your code here
payload.push({“variable”: “timestamptab”, “value”: dataresult},
{"variable": "ppctab", "value": PPCstatus},
{"variable": "gpstab", "value": gpsstatus},
{"variable": "batterytab", "value": batstatus},
{"variable": "speedtab", "value": speedtab},
{"variable": "lattab", "value": latresult },
{"variable": "longtab", "value": longresult},
{"variable": "voltagetab", "value": voltagestr},
{"variable": "odometertab", "value": odomconvert}
you can do like this:
const mySerie = Date.now();
// creates a unique identifier for each series, in this case it takes the current time
payload.push({"variable": "timestamptab", "value": dataresult, "serie": mySerie},
{"variable": "ppctab", "value": PPCstatus, "serie": mySerie},
{"variable": "gpstab", "value": gpsstatus, "serie": mySerie},
{"variable": "batterytab", "value": batstatus, "serie": mySerie},
{"variable": "speedtab", "value": speedtab, "serie": mySerie},
{"variable": "lattab", "value": latresult, "serie": mySerie},
{"variable": "longtab", "value": longresult, "serie": mySerie},
{"variable": "voltagetab", "value": voltagestr, "serie": mySerie},
{"variable": "odometertab", "value": odomconvert, "serie": mySerie}
Thanks a lot for the help!
It worked here!
