Error on running sample analysis
Hi, On running the sample geofence example, I encounter these errors. What am I doing wrong? Thanks.
[2021-10-15 13:45:22] Analysis finished.
[2021-10-15 13:45:22] (node:273) UnhandledPromiseRejectionWarning: Device can’t be found
(Use
node --trace-warnings ... to show where the warning was created)
[2021-10-15 13:45:22] (node:273) UnhandledPromiseRejectionWarning: Unhandled promise rejection.
This error originated either by throwing inside of an async function without a catch block, or
by rejecting a promise which was not handled with .catch(). To terminate the node process on
unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see
Command-line options | Node.js v17.1.0 Documentation). (rejection id: 2)
(node:273)
[DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future,
promise rejections that are not handled will terminate the Node.js process with a non-zero exit
code.
[2021-10-15 13:45:22] Running
[2021-10-15 13:45:22] > TagoIO-SDK: No region or env defined, using fallback as usa-1.
[2021-10-15 13:45:20] Starting Analysis…
[2021-10-15 13:45:20] Analysis Called.
Hi @surya.sarda showing just the error log is impossible to provide you any assistance.
How are you triggering the geofence script?
Did you make any changes on the geofence snippet? Can you provide the code that you are using?
Also, notice that you can set a catch to console log the error from your getDevice call. (or any other calls)
