Decimal points in Image Marker
Hi community,
I need your help to solve a situation with formulas in Image Marker widget. I’ve created a new image marker in a dashboard and i need to apply a formula to adapt the variable shown, but once i apply the formula, the pin shows a lot of decimals in its information box as shown in the image.
How can I reduce the decimals in info box?
Thanks for your support!
Did you enabled the number of decimals for the variable? It should be in the same screen where you apply the formula.
Hi Vitor,
It seems i don’t have the same interface… i don’t see that option in formula section of Image Marker.
The image I sent you was from the Blueprint Dashboard.
For the normal dashboard, this option is under the “Date Range & Format” section.
