@Andrew Sevil
Hi everyone, I have a number widget showing rainfall, which can have a large number of decimals. I have selected the widget to only show 1 decimal, but it doesn’t work. Screenshot below.
Any thoughts?
@Aline Tusi
Hi @sevils,
Can you check if you are sending the data as number or as string?
I’m waiting for your reply.
@Aline Tusi
Hi @sevils,
The Display widget respect the type of data.
This means that it will respect the data separator, in this case, the data type is number.
e.g.
“variable”: “temperature”,
“value”: 71.999999
If you send data as a string, it won’t respect the separator.
71.99999 = number
“71.99999”= string
To fix it, I suggest you change the data type to number.
@Andrew Sevil
Ok, thanks @alinetusi I’ll make the change and check the result. Interesting that it works ok for the blueprint dashboard though…
@Andrew Sevil
Works fine, thank you!
