Custom domain - replacing the xxx.run.tago.io
As per today, when you select the Whitelabel add-on in your account, you are eligible to select the first part of the url while the .run.tago.io is automatically added to it. For example, you could pick assettracking.run.tago.io, or assetcounter.run.tago.io for your TagoRUN. (if it is available).
If you want to add the TagoRUN to your domain, let’s say for example that it is mycompany.com, you can still get it by adding the Custom Domain add-on on your account.
After you have done the upgrade, you can open a ticket (just click on the blue button ‘Contact us’ as shown in the image below, and mention what is your desired URL. We will send the registers that you need to add in your DNS.
The URL should contain all domain, for example: myiot.mycompany.com
Notes:
[1] only sub-domains can be added in your URL (left side of your domain). In this case, you can pick myiot.mycompany.com, but can not pick mycompany.myiot.com
[2] when you add your Custom Domain, the e-mails sent from the system will not longer be from @tago.io , but as from your own servers @mycompany.com. All references to TagoIO are removed.
