Chart X Axis values are not properly sorted sorting by serie
i have seen a strange behavior in chart -> “Order the samples by” function. I see that if i choose to sort samples by series the x axis continue to show values in wrong order. Please give a look to the uploaded example where i show the issues on Dashboard charts, and in meantime also what i print into context.log where the output, instead is correct.
I have solved the issue, modifying the Device.Insert method, like described in this other thread:
