Change device Networks and Connectors in bulk, now in the UI
Hi everyone!
Replacing devices with a different model? Moving to a new network provider? You can now change the Network and Connector for multiple devices at once, directly from the TagoIO interface.
Until now, you could make these changes programmatically through our REST API. We’re bringing that option to the UI, so you can update a group of devices without writing a script.
How it works
  1. Open the Devices page.
  2. Select the checkbox for each device you want to update.
  3. Click Edit at the top of the list.
  4. Choose Change Network & Connector.
  5. Select the destination Network and Connector, then click Next to continue.
Before completing the change, you’ll also have the option to export the serial numbers and their corresponding TagoIO device IDs. Save that mapping as a backup reference in case you need to troubleshoot the migration.
One important detail: changing the Network and Connector generates new device tokens. Update any integrations using the old tokens to maintain access. Existing serial numbers and stored data are preserved.
Have a device migration coming up? Let us know how this fits into your workflow!
