Bug in formula for image widget
@Graeme Rae
We have an image being created on a server:
http://www.server.com/data/d5923561-5842-4489-88f2-983829d7ea78.jpg
The filename is being stored on tago:
variable: filename
value: d5923561-5842-4489-88f2-983829d7ea78.jpg
My formula in an image widget is:
concat(“http://www.server.com/data/","$VALUE$”)
However the output URL is actually:
https://http//www.server.com/data/d5923561-5842-4489-88f2-983829d7ea78.jpg
Somehow there’s an extra “https” being tacked on the front.
If I use the same formula in a table widget and make it a link, the string comes out correctly:
Note - this specific server cannot serve https data, only http
Is this a bug? Or is there a workaround? Or am I doing something wrong?!
EDIT: Adding a little more…
Similarly - if I pass a complete URL to the image widget:
variable: filename
value: http://www.myserver.com/data/d5923561-5842-4489-88f2-983829d7ea78.jpg
And remove the formula completely (so it’s just pulling filename from the blueprint) nothing shows up in the widget at all. However the tabular version does show the correct URL and is clickable.
