how to make a blueprint map geofence? i can’t find anything to make a geofence
Hi @christian
The blueprint map doesn’t have geofences yet. This feature is a work in progress and it will be deployed soon.
ok… thanks I will wait
Hey @christian the blueprint map widget now has the geofence feature.
The simplest way to use it is through the widgets’ edit page, there is a submenu called “Geofence”, in this menu, you can enable users to edit geofences and choose the draw options for a geofence.
In this modal, you can create a new geofence, edit an existing one or remove it, when you save it, everything will be store at the variable that you choose at the widget’s edit page, in my case it would be at mydevice - geofence.
