Adicionado disjuntor na tagoio
É possível adicionar hoch disjuntor zjsb9-125z com tagoIO? E se não for possível, quais disjuntores podem trabalhar com a tagoio? agradecido.
Oi @felipelatapiat, bem vindo a nossa comunidade!
Em breve um dos nossos técnicos ou usuários irão responder sua pergunta.
Abraços!
Hi Felipe,
I don’t know your hoch zjsb9-125z sensor. Almost any sensor can be integrated with TagoIO. If you don’t see it on our already supported list of sensors, you can do the integration by yourself.
You will need to connect your sensor to TagoIO using a LoRaWAN, MQTT or HTTPs integration, which is described here:
Network Integration - TagoIO
Sending Data - TagoIO
And after your device is connected to TagoIO, if needed, you can use the Payload Parser to decode or normalize your information to TagoIO: Building your own parser - TagoIO
