Hello everyone. I need an example of analysis that can sum up the data that arrives from a certain variable. The total amount has to be shown on the cylinder widget.
I have no experience with codes, thank you if you can give me a ready example.
Hi Leandro,
Sorry for the delay, I’ve just finished creating you an analysis example for your need. I will paste the code below.
const {Analysis, Utils, Services, Account, Device, Types} = require("@tago-io/sdk");
import getDevice from "./lib/getDevice";
import { parseTagoObject } from "./lib/data.logic";
async function handler(context, scope) {
context.log(JSON.stringify(scope));
context.log("Running Analysis");
//must have the environment variables set at analysis -> environment variables
const environment = Utils.envToJson(context.environment);
if (!environment) {
return;
if (!environment.config_token) { //blueprint device token
throw "Missing config_token environment var";
} else if (!environment.account_token) { //profile token
throw "Missing account_token environment var";
//instanciating user device and account
const config_dev = new Device({ token: environment.config_token });
const account = new Account({ token: environment.account_token });
const customer_dev = await getDevice(account, scope[0].origin);
//choose the variable name to sum up here
const result = await customer_dev.getData({ qty: 9999, variable: "temperature" });
//data to be saved on bucket
const data_to_bucket = {
sum: 0,
//looping through each object found and summing up the values
result.forEach((x) => (data_to_bucket.sum = data_to_bucket.sum + x.value));
//parsing data to tagoIO structure to be saved on bucket
await config_dev.sendData(parseTagoObject(data_to_bucket));
//fetching the data saved on bucket -> e.g. you can use this information on a widget
const finalSum = await customer_dev.getData({ query: "last_item", variable: "sum" });
//console logging the final result
console.log(finalSum[0].value);
try {
await handler(context, scope);
context.log("Analysis finished");
} catch (error) {
console.log(error);
context.log(error.message || JSON.stringify(error));
//insert your token heres
export default new Analysis(startAnalysis, { token: "28cf6f8b-a9d7-4ed1-b328-353ddded62c9" });
Remmembering you that we provide further support if needed, please dont hesitate in contact us.
Thank you.
Guilherme Oliveira
