Accesing data from external sources - TagoBuilder issue
@SA
[Updated]
I tried the Analysis-Builder to get a script that accesses Azure SQL. However I was getting a runtime error when the generated script was uploaded. I have opened a support ticket however, it would really be helpful if a detailed working example of accessing external DB is provided.
I tried to follow along the documentation:
https://docs.tago.io/en/articles/174-running-analysis-as-external-using-node-js
But this contains a broken link:
More instructions on how TagoIO-Builder works and what you’re able to do can be found clicking here.
Also, on Windows, the Analysis-Builder is not automatically on the path.
Thanks.
